nissen radiator
Get the Nissens from rock auto.
I paid about $230 shipped.
OK - I have a write up in this BB Forum. You will need to use SEARCH and find it for replacing the radiator.
Basically -
The radiator is attached with rubber mounts to the bottom and TWO plastic holders per side around the middle.
Your job - is to get the metal retainers OFF of the RADIATOR.
These are screwed in behind the HORNS and some other crazy place.
Then you unhook all 4 fluid transfer pipes - two to the oil cooler two to the trans cooler.
Unhook the hoses - two large and one plastic hose.
Unhook the wire for the SAI.
The radiator will then LIFT OUT as an entire assy with oil cooler and trans cooler attached.
Don't be stupid and dissassemble the radiator in the truck..
Get it out.
Put it side by side with the new one.
Transfer ALL the hardware and coolers.
Put it back in.
To get the grille off you need a LONG screw driver to put thru the wheel wells to a screw holding trim on.
I have a post on ALL this I did last year.
Search on jfall posts.
Basically -
Get it out.
Put it back in.
