No compression on #1 on Disco 2?
A buddy of mine has a 2000 Disco 2, and it has a miss. He pulled all 8 plugs for a compression test and cylinder #1 was at ZERO. All others were between 145-150. No coolant issues / smoke, etc....any thoughts? Thanks -
sounds like you need a rebuild......
pull the heads and take them in....have the shop look for a bent valve....if they are good...have them cleaned up and a valve job done and have the heads decked!!!
change the gaskets and get her running again
Mikey1976
Jul 1, 2010 10:35 PM
95GreenDisco
Dec 4, 2008 09:32 PM
