No more resonator...
A few pics of my new exhaust setup:
I cut the exhaust at the lowest bend and put a tip and clamp on it. Make sure to buy a 2.5 inch diameter tip so it fits over the factory tubing. It sounds great and cost less than $25.
I'll upload a video to Youtube in a bit.
Cheers,
Pete
Cheers,
Pete
RE: No more resonator...
Yeah consider putting a few inches extension on that to get it out past the body work. Overtime that stuff can actually rust the undercarriage and paint.
Anyway, is that legal? Will it pass emissions like that? And how much louder is it? Sickeningly loud or just a nice grumble?
I only ask because I'm considering the same thing myself.
i did sort of the same thing... i ran seperate pipes from each cat and then ran them through glaspacks and put the tips out in front of the rear tires... but i am about to change it because on our last off roading trip my passenger side pipe hit a stump and got bent back to my tire, i bent it back with a stick but the hanger is still broken...
ORIGINAL: Darover
Not good. The tip of the exhaust has to be taken away from under the truck. otherwise, at a stand still or in traffic, the fumes will get in the cab and make you sick or worse !!!
It should not affect emissions (at least not for Texas).
The sounds is a nice burble at idle. You can't hear it unless the windows are down or you really hammer it out on the road. This video shows what it sounds like (not my Rover):
http://www.youtube.com/watch?v=XtdNJtjKiFI
Cheers,
Pete
Update:
From the Texas DPS:
http://www.txdps.state.tx.us/vi/insp...ejectsubmit=Go
j. The tailpipe fails to discharge exhaust from the rear or sides or top of the passenger compartment of the vehicle.
ORIGINAL: Disco2Guy
Do you do much water crossing? I'd be afraid of water rushing up through the tailpipe if the engine ever died. What made you choose the lowest point to make the cut? From the pics it looks like the tip is sitting lower than with the stock resonator.
ORIGINAL: Switzer
And I think what you did will work, mine is shorter but still angles down and I never have any problems. DiscoMike would same the same I believe, judging what he's said in the past.
ORIGINAL: Camdisco24
Good choice of video. (cough cough:: its mine!)
ORIGINAL: Switzer
I think the way I have it set up works quite well. I would have to try pretty hard to wack the tip off road as it sits right behind the axle (behind the rear shock mount). I'm sure if I were idling my Rover for 15 minutes in a closed garage exhaust gases might be an issue.
For the cost and sound I recommend everyone go out and chop that resonator right off. It really adds character to the Rover and lets me know I actually have a V8 under the hood. Most friends assume its a V6 listening to the exhaust (nevermind the V8 badges on the outside).
Cheers,
Pete
