No start please help
Hi guys,
maybe you can help me out here, i'm on countless fourums and no resolution. first of all my starter is good, ignition switch good, no imobiliser problem, not the starter relay, not a blown fuse, not grounds, and not the battery. ok so my car is not getting power to the starter and will not start, any ideas? any help would be great, thanks. 95 disco auto.
by the way hello to everyone!
RE: No start please help
Have you put a socket on the crank pulley and confirmed that the engine can be turned over by hand?
Sounds obvious, but I've seen more than a few cases of people tearing their hair out trying to turn a engine over that was locked up.
Geoman
www.eurotekapg.com
Geoman
www.eurotekapg.com
You might want to take a look at the immobiliser 'spider'; it'sa separate black box under the centre of the dash sandwiched between the radio and the heater. It controls power feeds to starter motor, fuel pump, ignition, fuel cut offetc depending on whether diesel/petrol. They are well known for having problems caused by dry solder joints and can either be repaired or replaced with a jumper plug that takes the troublesome box out of circuit. A quick google on 'discovery spider' or 'AMR4889' should give you the links you need. Good hunting!
EDIT: I re-read your original post and noted that you state no immobiliser problem.. IIRC the 'spider' is separate from the main immobiliser.. so might still be the issue. This is a common no-start/intermittent cut-out issue, so bad in fact that LR created the jumper plug as a factory modification to eliminate the 'spider'.
