Noise when steering? what to grease?
I have an 03 Disco with 63k miles. When I turn (usually only on first turn out of the driveway) there is a slight squeaking/groaning metal on metal noise coming from either the steering column or some part of the steering linkage. Any suggestions on where to lube and what grease or lube to use?
I have a simular noise when I turn at a faster speed. Sounds like a coil spring groaning. All my fluids are fine. I don`t have ACE. I`m going to replace my isolators when I install my lift. Already have everything, just need to get my butt in gear and install it when I find a nice garage to do it in.
Good luck with yours, Bob
I have the same symptom as you: one groan, the first time you rack the wheel from dead cold. I suspect it might be a belt going shiny; once it warms up even a little bit it has the torque to handle it.
If you serp is at all old, you might replace it and see what happens. Check it for shininess and cracks, and check your tensioner.
