O2 sensor Codes
O2 sensor Codes
My CEL is on and I have the following codes: P0141 P0161 P0160 which are both downstream O2 heater circuits and the bank 2 O2 sensor. Is there a good way to make sure it's the O2 sensors that need to be replaced rather than a wiring/ECM issue? I've checked the 15 amp F2 and it's intact.
Thanks for the reply. I've got two new NTK sensors but I was hoping to check the circuit before I drop them in since they were like $75 a piece. Were you getting the same code?
I think the circuit is good. getting 12 volts on the brown wire and the ECM seems to be pulsing the white wire to ground when the car is started. Still getting the 141 and 161 codes with a new NTK sensor (only changed one). When you guys get bad sensors out of the box, is it the sensor or the heater or either one that doesn't work? Could I have received a sensor that has a bad heating element?
