O2 sensors failing after 6k miles?
UPDATE: I heard from the shop, sensors checked out fine and they found a worn wire. They replaced it, and the check engine light has stayed off.
Now, the bad news, they found coolant stains on the driver side head, so there is a bad gasket there. This shop doesn't even want to touch it, and would want too much to do it anyway.
Now comes my choice. I've been considering selling it since I have an 18-month at home, and time and money are short at the moment. Or do I attempt to repair it myself? I'm just okay at this stuff, opening up a motor would be a big job for me especially.
I've put a lot into it, and the truck has job really good things going for it. For now I'm going to list it in the classifieds. If anyone is interested, make me an offer. I have a detailed record of what I've done to it, and it has $800 worth of brand new tires on it. Brakes are new, much more.
Clearly not a Rover shop, better off not having them go deep.
Just for kicks, on the drivers side are there signs of coolant ON the top of the valve cover?
It is common for the throttle body heater to leak and that drips down on the head between spark plugs 3 and 5.
So look before you sell it, thats the difference between a $20 fix and a $2000 fix.
That's not a bad thought, but the shop said you can see it coming out of where the head meets the block. Definitely going to need an HG. Really not ideal timing for me at the moment...oh well, at this point if I can minimalize my losses and see it go to a guy who has the time to fix it, that would be good enough for me.
I'm in Cleveland, Ohio. And I hear your other thoughts, still considering doing it myself. I do love the truck. That all being said, if someone would make a decent offer I would more than likely take it.
Also, I see that I could get the kit around $200, then I would think a machine shop would want at least $200 to mill the heads. I've done things like bearings, brakes, water pumps, but opening up a motor would cause me some anxiety. haha Have you done this before? I do have the RAVE manual downloaded, and have heard about the In Search of Experience DVD that apparently has a HG job on it. Still though, I am doubting I can do this.
Engine Refresh (top end) | PaulP38A.com
there re is a link to a website of an Aussie that did it and took great pictures. If you wanna do it yourself and keep it, shoot me a pm and I'll help anyway I can as I'm sure anybody on here would.
Muggs (01-31-2017)
You know, you're persuasive, you're starting to sell me on this. I was planning on doing this preventively this summer anyway (was also going to add an oiler cooler and redo the headliner - I had big plans). The timing of this couldn't be worse, but at least I caught it and could address it.
Thanks for that post! I'll check it out. Would you recommend the In Search of Experience DVD? Are you familiar with that?
