OBd2 Code 2539
After discussing this with a Land Rover master tech, it appears that the fuel delivery is regulated at the pump. There is no "return" loop as on earlier vehicles, regulated by a pressure switch. So-- it's looking like you have either a weak pump (in the tank) or the sock filter is partially obstructed with crud.
regards,
Geoman
www.eurotekapg.com
regards,
Geoman
www.eurotekapg.com
Thanks.
As you might have guessed from my inquriy, I don't know much about LR's. Can you tell me about this "sock" filter that has been referred to? Is it actually in the tank? Can I get at it and clean it, if as you speculate, it is crudded up? Are the sock filters available at normal autoparts places, or is it Unique to LR dealerships?
Thanks,
Mason
Thanks,
Mason
The sock filter is on the end of the fuel pick-up tube, and this whole assembly-- that includes the fuel pump-- is inside the fuel tank. If it was me, I would first have a pressure gage fitted to the fuel rail on the engine (there is a fitting there for this purpose) and see exactly what is going on. The measurements needed are:
Pressure when just turning the key to the on position (engine not yet running)
Pressure when the engine is running at idle
Pressure when you bring the rpm up to about 2000
In addition, you need to observe the gage after engine shut-down and see if it is "holding" pressure (for at least 30 minutes).
This diagnosis will tell you if you have more than just a partially obstructed sock filter. Get those values and post them here. We can then give you better advice.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
