Odd knock when braking or accelerating
The 2004 has been exhibiting a weird knock and I'm stumped. It goes like this - slow down to a stop, and within the last few feet of approaching a stop sign - one subtle knock. Then leaving from a stop, within the first few feet, another subtle knock. It's pretty dull. Definitely something in the front suspension. Sounds like it's coming from the front-right wheel area. I can idle/coast down the street and manufacture the sound by just braking, accelerating, braking, accelerating, etc. It's so predictable, I can do that and almost make it sound like a metronome.
The puzzling thing is that the front suspension is entirely new, other than the radius arm bushings. Ball joints, panhard rod bushings, steering rods and rod ends, front shocks, wheel bearings, CV joints, differential, sway bar links, sway bar bushings - all new within the last 5000 miles. I feel like the lateral, forward-rearward motion that causes the clunk could make the radius arm bushings suspect, right? But even still, the entire truck is only at 96K, and that seems super pre-mature for radius arm bushings to fail, yeah? I don't know.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
The Deputy (12-28-2021)
It is an age thing, you're right. Wonder if those would play into this? The knocking never occurs on bumps or anything that would cause the suspension to move up and down. It's only a fore and aft situation.
Definitely not driveline slop. I know that sound well, haha. It's definitely coming from the right-front wheel area. Maybe it's one of the new wheel bearings? I've certainly had issues with them in the past.
Received 1,189 Likes
on
Yep, both good places to look, watts (the watts would be moving up and down from merely stop and go driving, while braking - rear of body unloading suspension, acceleration - loading rear suspension) and motor mounts. Plus, rechecking previously done work never hurts.
Brandon318 (12-28-2021)
