Odd noise going uphill?
That was hard to hear. Years ago I had a intermittent tapping noise under load (going up a hill) which turned out to be my water pump shaft being loose causing the fan blades to rub on the shroud. New water pump fixed that noise but it returned recently because the oem fan had a wobble. Dorman fan replacement when I did all gaskets 2 weekends ago.
Anyway, I replaced the water pump last week, but resulted in no change. It's been making that noise for the last several months.
What year is your Disco? With the engine idling, does the fan spin smoothly, or does it have any wobble?
I do, yep. Good thought though. It's such an intermittent and oddly-occurring issue. Like... why only uphill at highway speeds? I would presume it has something to do with the kick down of the transmission, but on flatland a kick down into a lower gear doesn't produce the same symptoms. In other words, I don't understand why the uphill factor is the issue here.
