OEM mudflap mounting
Old Jul 23, 2020 | 07:05 PM
Disco Aaron's Avatar
Default OEM mudflap mounting
Recently purchased some used mudflaps for my 04 DII. I suspect it came with them when it was new but they were gone when I bought it and I’ve always liked the look of them. However, I can’t seem to figure out how the front pair mount. There are zero holes that line up anywhere. Same issue with the smaller rear one that mounts in front of the rear tire. Am I missing a bracket or something else? Pictures of how they mount would be very helpful. The rear most one seems fairly easy and already has holes.
Old Jul 23, 2020 | 07:47 PM
zski128's Avatar
The rear flaps in front of the rear tire mount to the body mount. There is a metal bar with two studs that hold it on. See pic below it was taken with the rear passenger tire removed just next to where the radius connects.
The front flap mounts to a metal plate just like the rear most flap. If your truck didn’t have front mud flaps that plate might not be there.
Old Jul 23, 2020 | 10:51 PM
Definitely don’t have a metal plate in the front. I’ll see if I can source one from a part out or something. How is this plate connected to the body?
Old Jul 24, 2020 | 11:34 AM
XRAD's Avatar
nuts and body mount bolts. there are soooo many pics on the net...
here is one part number showing you the mount.....Rimmer Bros
Discovery 2 Mudflap Bracket Front RH - CAX100060 - Genuine
mgbowen
Mar 11, 2020 10:46 AM
spazzz2002
Freelander
Jul 27, 2013 09:31 PM
nashville rookie
Jul 23, 2012 03:41 PM
yloDiscoII
ROAMING WITH FRIENDS
27
Aug 21, 2010 07:18 AM
RjBu
Sep 30, 2009 07:40 PM
