OEM Suspension Options
OME Suspension Options
Well, its probably about time that I replace my suspension and shocks, and I've been interested for awhile in getting a lift on the Disco, and so I was doing research and came across the popular OME 2" Suspension Kit (I've read it provides about 1.5-2" of lift), so it seems this combines the best of both worlds. My only question is whether I should go with medium or HD? Eventually I would like to have a winch on the Disco, and I know that as I keep adding weight I'll need more tension to keep the sag up, but before I do any of that, would HD be overkill? My Disco isn't going extreme rock crawling and is a hybrid commute/ have fun outdoors truck at the moment. Eventually I would like to make the Disco into an off-road only truck, but that won't be any time soon, but I'm also not trying to spend $700 now, and then replace a bunch of stuff later because its not strong enough.
Any recommendations? Has anyone taken a mostly stock Disco II and used OME HD suspension and noticed if it was a really rough ride before they loaded things like a winch on?
Thanks,
Phillip
Thanks,
Phillip
on
In other words, go to the 779 front coils and the 762 rears along with the new OME Sport shocks and their steering stabilizer.
It will take about a month of driving for the coils to adjust in, but you will get 2"s from it along with a great ride and then later if you want to go to a winch/bumper you can still do it without changing the front coils again.
Check out the prices from Lucky 8, they have one of the best over all prices for the package.
In other words, go to the 779 front coils and the 761 rears along with the new OME Sport shocks and their steering stabilizer.
OEMPartHaus.com
Member Group And Special Buys
05-28-2015 08:59 AM
fastrx7man
01-28-2012 12:49 PM
rjhagan
06-04-2007 04:12 PM
