Oil light intermittant after timing cover gasket change and now headgasket too?
Old Apr 2, 2013 | 12:25 PM
shezm's Avatar
Yes 17 ft lbs rings a bell.
I changed out the oil pump gears. The Oil filter/Rotella thread has me interested. I'll acquire a oil pressure gauge first and go from there to see if the filter change makes an improvement. Right now i dont know if its going to 5psi or 0psi (scary).
Old Apr 2, 2013 | 12:38 PM
244 degrees will kill that engine so no more restarting it, if you can help it.
As for the white smoke, took my truck 25 minutes of driving before all the coolant was burned from the exhaust system.
Let us know what you find.
Old Apr 2, 2013 | 01:40 PM
jfall's Avatar
Your oil pressure is LOW as the antifreeze has damaged the bearings on the crankshaft and the oil is just blowing thru.
You could spin the crank if you keep running it.
I would fix the antifreeze leak first - in the timing cover.
If the heads are bad again , well that may get antifreeze into the oil via the valley gasket if there is a coolant leak at the valley gasket.
And lastly, once all that is done, to regain oil pressure, you probably need to replace the engine bearings if they are showing copper.
Also - I have heard that the oil pump in an '03 can be assembled bad from the factory and the oil pump gears can get cracked and there is an alignment issue with the timing cover.
Sorry to drag all this bad stuff out but - needs sorted.
Old Apr 2, 2013 | 02:01 PM
94svt50's Avatar
Another common problem with the timing cover if the gasket shifts slightly if over tight and it will dump coolant into the oil pan and dilute your oil, dropping your oil pressure and overheating. Pull the dipstick and check for contamination.
Old Apr 2, 2013 | 05:23 PM
shezm's Avatar
I have already done rhe timing cover, oil pump gears, and chain. Going to stick to checking the oil pressure and see if I can get it to go up. Once I can do that I know I have an engine to invest a head gasket job in. A compression test should tell me if a cylinder is not holding and if its a corner cylinder I can surmise the head gasket is definately an issue.
Old Apr 2, 2013 | 05:47 PM
94svt50's Avatar
have you looked at your oil to make sure the timing cover has not flooded it with anti freeze?
Old Apr 2, 2013 | 05:53 PM
jfall's Avatar
OK then I am betting your lower mains are out of tolerance and your big end rod bearings are out of spec and showing copper.
The antifreeze in the oil will confirm.
When you changed your oil - if you did it in the sunlight - you'll see the small metal bits glinting in the sun..
If your oil pump is OK
and you have had antifreeze in your sump then gotta be your main and big end rod bearings are allowing too much oil out..
I would go to Rotella 20-50w if you continue to run this way.
Never synthetic.
I bet at idle there is a slight lower end knock.
The only other place oil can leak is up at the rocker arms and the rocker arm shaft.
If one of those is loose - or worked loose or you forgot to torque a bolt on one of those then that might do it.
Old Apr 2, 2013 | 08:24 PM
dscostk's Avatar
Did you put the oil pump gears in correctly? There is a right and wrong way to put the outer gear in.
Old Apr 2, 2013 | 10:01 PM
Why did you replace the oil pump and timing set?
Was there a problem with them or just the leaking gasket?
Old Apr 3, 2013 | 06:39 AM
shezm's Avatar
The replacement gears (atlantic british ) are not marked on either side and searching the forum showed they could go in either way. Are there typically markings on the outer gear to show otherwise?
