Oil light/knocking noise
I have a 98 Disco I and there is a knocking in the engine, not to mention when the vehicle stops the oil light comes on. When the a/c is running the oil light comes on even with the vehicle moving. We replaced the lifters and the oil pump but the knock is still there and the oil light is still on. Any ideas????? Thanks
RE: Oil light/knocking noise
This doesnt sound good 98. It sounds like an internal problem , lifters,rings or valves.I assume it has enough oil in it? What color smoke comes out of the exhaust at startup? Does the lr jump around while the knocking is going on? Check Ignition first ( plugs , wires, distributor or coil).See if the plugs are wet.( water is a bad sign) Oil is not so good either,A little fuel is ok , but not sopping wet
Maybe you'll get lucky and it wont be anything major.Was it doing this before you put the oil pump on?
apancho
01-22-2007 12:47 PM
tobob1
11-27-2006 02:11 AM
