Oil pan gasket leak
I changed my oil pan gasket out while making other repairs awhile ago. Since then I've always had an oil leak when driving at speeds above 60 mph. I reviewed the steps for install in the FSM and noticed that it calls for RTV to be applied near the bellhousing end of the pan; this is something I didn't do. Would this be my issue? Why is RTV needed with such a thick gasket?
x1 Yep, sadly RTV rules OK. I use on one side of the gasket only, mostly to hold it in place, then bolt up loosely and wait 10 minutes (depending on the ambient temperature) then torque up as stated. Always use RTV on the front and rear where the crank is otherwise it nearly always leaks.
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
