oil pressure numbers
Old 04-17-2010 | 12:33 PM
jck09's Avatar
Default oil pressure numbers
cold @ idle - 42-45
cold @ 2000 - 48-49
hot @ idle 8- 10
hot @ 2000 44-46
oil light is not on. no bad engine noises. slight intermittant lifter tick. truck has 120000 on it and it is an 03 within the range but i do not believe the pump has ever been replaced. what would be causing the psi to be so low at idle but ok at 2000? i am running rotella 15w40. thanks in advance everyone
john
Old 04-17-2010 | 01:29 PM
Your pump is starting to show its age. The difference between hot and cold at idle is normal.
My only concern is the hot idle number, 6 to 8 and you are about to get into trouble.
Old 04-17-2010 | 01:41 PM
Disco2Fever's Avatar
How do you check your oil pressure? I'd like to monitor mine.
Old 04-17-2010 | 07:46 PM
jck09's Avatar
mechanical oil pressure guage in the truck. mike, do you think i could get away with only the gears or will i need the entire cover?
john
Old 04-17-2010 | 08:08 PM
greg409's Avatar
Originally Posted by jck09
cold @ idle - 42-45
cold @ 2000 - 48-49
hot @ idle 8- 10
hot @ 2000 44-46
john
The rave manual cals for 10 psi @ idle min. (hot or cold)
50 psi cold @2000 (relief opens @ 50psi)
The idiot lite makes @ 3.5 -- 6 psi
So, you're not in terrible shape.
read your other post
luck,greg
Old 04-17-2010 | 09:20 PM
jck09's Avatar
john
Old 04-17-2010 | 09:24 PM
lipadj46's Avatar
I think your numbers look fine.
Old 04-17-2010 | 09:45 PM
greg409's Avatar
john
You can do whatever you want, the factory overhaul manual shows your numbers are ok.
I suggest you download the rave cd in my sig, as it is complete - you'll find any thing you want and more than you need.
I started mechanics in 1959, it saddens me to see people change parts unnecessarilly
as they try to chase down a problem.
Most of us here have sorted out nearly anything you'll encounter and enjoy sharing.
It's up to you to determine what route you take.
If you re-read the responses to your post, take the average.
The "this happened to me" stuff is nice, but if it doesn't offer sound advice, it's just clutter.
It's my understanding that the oil pump issue is a result of alignment dowels IN THE ENGINE BLOCK were misaligned, the factory tightening of the timing cover ***'y stresses the housing, possibly resulting in cracking later.
I don't know if it's always inevitible, but there is no factory repair outside of replacing the block or engine.
oil pump gears won't resolve it. - a complete oil pump housing may/may not forestall it if it's going to happen to yours
there's something to the fact yours has made it this far.
please keep us posted
luck,greg
Old 04-18-2010 | 05:05 AM
jck09's Avatar
thanks greg, ive already downloaded the rave and its een a big help so far. i know that for the 03s with the misaligned dowels the only fix is a new block. but i was wondering if mine has made it this far and the gears are just worn should i just change the gears or the whole cover. i know that the numbers are within "ok" range but iv seen some way better numbers. im jus wondering all this just in case the numbers start sliding a little more. maybe catch it before it damages the cover?
thanks
john
Old 04-18-2010 | 07:54 AM
As I posted earlier, I would be concerned and as mentioned, you have a ways to go before it does cause problems. Check it in another year and if it drops any more then consider a pump kit.
Just out of curiosity, what weight oil are you using?
Quick Reply: oil pressure numbers
