omg!!! iNEED HELP WITH CROSSED BATTERY
hey guys,
long story short, i accidentall crossed the battery on my 2003 D2 while installing a extra battery i had laying around. The engine will barley run now and boy do i have codes.WTF am i gonna do. i just spent 6k $ on a rebuild and i did this while in hte parking lot of the shop. Please guys i need help.
i have the following codes
1451
0414
1482
1884
0445
0448
0102
0340
0134
0154
1451
0414
1482
1884
0445
0448
0102
0340
0134
0154
None of those were there before? Clear them and see what comes back...
P0414 SAI vacuum solenoid valve short circuit to ground
P1415 Secondary Air Injection System – Malfunction Bank 2 RH (Insufficient SAI flow
during passive test)
P0102 Mass or volume air flow low input MAF signal < minimum threshold, which is speed
dependent
P0448 CVS valve short circuit to ground
P0340 Camshaft position sensor circuit malfunction Open/short circuit to vehicle supply or earth
P0134 O2 sensor circuit no activity detected (bank 1, sensor 1) Front sensor LH bank open circuit
O2 sensor circuit no activity detected (bank 2, sensor 1) Front sensor RH bank open circuit
P1184 is a doosey:
(11)
* CAN message:
Engine friction invalid
No apparent effect. On Off
P1884
(18)
* CAN message:
Throttle position invalid
Substitute throttle angle of 50% adopted. No
kickdown. Operates in economy modes only.
On On
P1884
(19)
CAN message: Engine
temperature invalid
Substitute engine temperature derived from
other inputs. No apparent effect.
On Off
P1884
(20)
CAN message: Road
speed invalid
No apparent effect On Off
P1884
(33, 34)
* CAN message:
Engine torque invalid
Substitute engine torque of derived from other
inputs. May affect shift quality.
On Off
P1884
(35)
* CAN message:
Engine speed invalid
Maintains current gear in low range, limp
home mode in high range. Shift pressure to
maximum, harsh gear shifts/engagement.
On On
P1884
(37)
CAN message: Engine
air intake temperature
invalid
dependent
P1184 is a doosey:
(11)
* CAN message:
P1884
(18)
* CAN message:
On On
P1884
(19)
CAN message: Engine
temperature invalid
On Off
P1884
(20)
CAN message: Road
speed invalid
P1884
(33, 34)
* CAN message:
On Off
P1884
(35)
* CAN message:
On On
P1884
(37)
CAN message: Engine
invalid
