Overheating with no visable coolant leak.
I bought a 2004 Discovery with 75k and started driving it back home. Traveled about 90 miles and stopped for fuel. Getting back on the road as i accelerated onto the interstate the temp started to rise. Pulled off and found the coolant level low. Replaced about half gallon and drove another 200 miles on the interstate without trouble. Stopped for the night and replaced about 1/2 gal in the morning before heading home. Traveled another 200 miles before siting in traffic just off the interstate and had another temp rise and a need for another half gallon of coolant. I see no exterior leaks. Bought a replacement thermostat hoping that is the problem but where is the coolant going? So i suppose I am burning it off thru a leak in the head gasket? Haven't replace the thermo yet and also have Blue Devil Head gaskets fluid to try. I am not a real mechanic and am afraid to do anything without experienced advice. HELP!
Go to autozone and get the head gasket/block tester. Basically the fluid changes colors when exposed to CO2 in the coolant reservoir. That will tell you if you have a hidden head gasket leak/ block leak or a leak somewhere in your hose. In which case you might look into getting a pressure tester. Tough to find one to find Disco reservoirs though. Good luck!
Before major repair is taken on answer these questions first:
These are the list of things that can cause an overheat without losing fluid
1. Thermostat sticks or does not work
2. TRASH in front of radiator
3. Crap (stop leak among other things) has some of the radiator blocked up.
4. Water pump not operating at 100% due to worm parts (impeller)
I have had all of the above happen on one of mine so it is common.
ZMonet
06-24-2016 04:00 PM
aguison
11-18-2012 05:15 PM
