P0171 & p0174
Old Oct 7, 2010 | 11:56 AM
rcampbe's Avatar
5th Gear
Default P0171 & p0174
I am receiving the P0171 & P0174 error codes. I recently changed the plugs and wires and it has a new air filter.
Runs and idles fine. Checked for vacuum leaks by pulling the the line where it goes into the plenum and it almost stalled out, so I do not think that is the issue. 2001 DII w/ 70,000 miles. Any suggestions are appreciated.
Old Oct 7, 2010 | 02:36 PM
'BamaBoy's Avatar
P0171 and P0174 means that both banks of your engine are running lean. What kind of air filter did you put in?
Old Oct 7, 2010 | 03:04 PM
rcampbe's Avatar
5th Gear
I got the replacement filter at the dealer as I was there to get a replacement for the hose that connects the radiator to the overflow tank.
Old Oct 7, 2010 | 06:37 PM
jkid's Avatar
The maf sensor sounds like a good bet to me but it could also be an air leak somewhere in the intake. I would pressure or vacuum check the intake first for leaks.
Old Oct 8, 2010 | 07:54 AM
As long as it is running OK, you have time to figure it out, so don't just start throwing parts at it. The from the air filter box to the t/body for a leak. The air filter box may have a bad seal, bad/broken clips or a crack. Check the o-ring between the iar filter lid and the MAF to make sure it is there and not cracked.
If at some time, you get a tranny code also, like a 733 or 734, then you do have a bad MAF and it will need to be replaced, not cleaned, ASAP.
Old Oct 8, 2010 | 09:27 AM
smoverstreet's Avatar
Mike is spot on with this. I had the 171 and 174 codes for a couple of weeks. I then noticed that the truck had difficulty shifting into overdrive. I was deciding on what to do (MAF or O2 sensors) and "not throw money at the truck" when the 734 code popped up.
Read through or search for the post "Ready to buy MAF" by cwood. It helped me immensely, and my truck has run noticeably smoother and with no codes or SES light for 500 miles!
Old Oct 8, 2010 | 12:04 PM
rcampbe's Avatar
5th Gear
Thanks all for the replies, I will look through everything as suggested and go from there.
DavidG
Dec 9, 2016 03:34 PM
Lonewolf_ky
Freelander
Nov 24, 2015 11:59 AM
SFMaster1703
Apr 3, 2014 06:39 PM
woophie
May 24, 2013 10:08 PM
mrb06lr3hse
Jan 1, 2011 01:33 PM
