P0175 & P1000 on Nanocom. P1171 & P1174 on BlueDriver (Bluetooth)
Is there any reason why there would be different codes showing on the different scan tools? I replaced the original O2 sensors with new Bosch sensors, cleaned the MAF sensor w/ electronics cleaner, checked vacuum lines going to SAI solenoids for leaks, reset the codes, and they came back after a hundred miles or so.
I get the same deal from the Nanocom vs the Ultragauge. It’s P0501 on the UG, but P1884 on the Nanocom. In my case one is on the tranny and the other is a general code.
