p0304 and rough idle
i did swap the plug first. looked okay. kinda smelled like gas, but figured that was because it wasn't getting spark. just for confirmation, i'm now (probably) getting misfires on both cylinders because plug wire from coil 4 (now on cylinder 6) is suspect and on cylinder 4 because it's got the wire from coil 6 and firing out of sequence? i've got new 8mm wires on the way, so i'll probably just wait and swap 'em all at once. as for the brake stuff, the lady i bought it from said that the shop told her the abs sensor needed to be replaced. done that a couple of times on my durango... hoping it's as simple on the disco.
No one answered this question for you. If you swap just the spark plug end of the wire, which sounds like what you did, you will undoubtedly get a misfire on 4 and 6: the engine (spark) management system is now telling those plugs to fire at the wrong time.
Many times, in my experience, a lone cylinder misfire can be remedied by replacing the plug and the wire to that cylinder. A bad plug can cause a wire to burn out as it tries its' darndest to deliver spark to that cylinder.
okay... swapped the wires without having to remove the air intake (not nearly as bad as I thought once I moved the SAI tube) cleared the codes, cranked it up and okay for a minute. seemed to run a bit smoother, but headed down the road, flashing service engine soon. still seemed to be running much smoother. gonna swap plugs and see if that makes a difference, then maybe change them altogether. any other thoughts? thanks
I bought a disco2 1 month ago and had the exact same issue, flashing with P0304. I also replaced the plugs and wires with SAI. It didn't help immediately, but after 100 miles or so it cleared up.
I also cleaned and re-seated the grounding strap that connects the driver side firewall to the engine block. I would also notice the radio buffeting to the sound of the engine, after fixing up the strap w/ doing plugs and wires, shes running super smooth. I highly recommend taking a wire brush to the strap, unbolting it and re-seating it.
thanks samroy, will give that a shot. swapped plugs and the plug from cylinder 4 reeks of gasoline... cleared codes with same result... p0300, p0304, flashing service engine soon light. guess I'll get an inline tester to see if I'm getting anything to that plug, but that's the direction I'm leaning now... thoughts?
