P0307, p0300, p1590,
I had the same codes recently and it usually is wires... I have a bad O2 sensor that was throwing a code, so I grabbed an old one off the garage floor while waiting for new ones to arrive and swapped it in just to see what would happen. Shockingly, I got misfire codes... The precise ones you mentioned. Knowing nothing else had changed I swapped the old sensor back in and they went away. For what it is worth... Again, probably wires but put a scanner on it and see if you 1/1 O2 sensor is messed up.
How do I check if I have a bad coil? Would I just take cylinder number seven spark plug wire (Misfire is in cylinder 7) and attach it to another spark plug/cylinder? Like cylinder 5, and if I get a p03005 than the fault moved to another cylinder and its my coil? Can someone clarify this for me. Thanks. Or is it my wire?
It's a pain but the way to test one suspect coil is to swap the coils round.
I would swap wires first. Which is obviously just testing the wire. If the symptom persists in the same cylinder after swapping the wire, the coil is next in line to check.
