p0340 - camshaft sensor replacement, whats involved
Old Jul 12, 2011 | 12:38 AM
msm15's Avatar
Default p0340 - camshaft sensor replacement, whats involved
00 Disco 140K
Just picked it up, It has a p0340 code - I changed the crankshaft sensor just to make sure but it didnt help. What is involved in replacing the camshaft sensor ?
Thanks
Old Jul 12, 2011 | 07:54 AM
DarylJ's Avatar
Originally Posted by drowssap
you can check the RAVE but I believe you have to pull the front timing cover, if so you will also have to drop the oil pan also.
WHAT?
All you have to do is pull the belly pan and the oil filter. It's right there.
I'd try cleaning and reseating the connector before replacing it - they are in a pretty oily place.
Old Jul 12, 2011 | 07:59 AM
MSM
What exactly is your truck doing wrong and why would you replace a crank sensor for a cam sensor fault?
Read the Rave, it is an easy replacement.
Old Jul 12, 2011 | 10:25 PM
msm15's Avatar
Issues are rough idel and I got the CEL on. I changed the crank sensor because a lot of people said thats is usually the issue causing a p0340 and because it was a cheaper sensor - $60
I checked rave - unless I am missing something it doesnt really give you much details on the removal, it shows you where it is located but not how to access it or what to remove. Discomike where in the rave might you be referring too ?
thanks
couzteau
Aug 2, 2024 08:06 AM
twaszak
Apr 21, 2013 05:57 PM
grandkodiak
Apr 8, 2013 05:31 PM
94svt50
Apr 13, 2011 09:00 AM
imaric
Sep 28, 2010 09:04 PM
