P1450 Code
Old Jan 22, 2010 | 04:59 PM
CSPM's Avatar
5th Gear
Post P1450 Code
Hi Everyone
New to the forum, but an avid reader for the last couple of years. I have a 2003 Disco S with 89k miles and she has been experiencing a P1450 code every so often. Really cannot find any info on this code or where to look for the fault any help on this subject or someone that has experienced this and has found the solution would be greatly appreciated.
Old Jan 23, 2010 | 09:53 AM
It pertains to the Secondary Air Injection system. If not real mechanical, might want to have your mechanic find and fix the problem.
Old Jan 26, 2010 | 11:39 AM
CSPM's Avatar
5th Gear
Hi Mike
Thanks for your response. I will look at that again, I have been looking at the diagram for the SAI and other than replacing the solenoid which was throwing 1412 and 1415 codes in the past the 1450 one seems to be the most stubborn. Any recommendations as to where to look on the RAVE.
Old Jan 26, 2010 | 11:54 AM
lipadj46's Avatar
I don't even see P1450 in the shop manual. You can start by reading the "SAI System Fault Finding and Check Malfunctions" section in the shop manual.
pwaltrip
Jul 26, 2016 10:00 PM
hatt53
Mar 27, 2013 05:16 PM
pwaltrip
Sep 19, 2012 07:28 PM
sayeedA
Nov 15, 2011 11:02 PM
CSPM
Jan 29, 2010 06:27 PM
