P1590 & p0420
Hi Roverers!
Recently I was able to fix and clear a series of codes that had come up, basically by replacing the sparks & wires, these were:
Any feedback will again be very much appreciated, thanks in advance!
Regards!
P0300 - Random misfire;
P0301 - Cylinder #1 misfire;
P0303 - Cylinder #3 misfire;
P0305 - Cylinder #5 misfire;
P0306 - Cylinder #6 misfire;
P1300 - Catalyst damaging level of misfire on more than one cylinder;
P1590 - ABS rough road signal circuit malfunction; and
P1562 - Battery supply below 9V while engine running.
But after driving a couple of days MIL-free the indicator came back on. It now shows a code previously shown and a new one, these are:P0301 - Cylinder #1 misfire;
P0420 - Catalyst efficiency deteriorated - LH bank (NAS & EU-3 only); and
P1590 - ABS rough road signal circuit malfunction / Hardware is OK, but SLABS ECU is sending an error signal.
I'm sure the first would be a consequence of having driven the car long enough with the "misfiring" issues; the second: dunno.P1590 - ABS rough road signal circuit malfunction / Hardware is OK, but SLABS ECU is sending an error signal.
Regards!
