Panhard Bar
Hey - I put a 3" Tf lift on my truck and just heard about panhard bars - just wondering if that's something I need right away? Any way to tell? Any comments? I heard the Tf one is really good...?
The only thing I was told I needed when I got the lift was new brake lines which I did - now wondering if I need one of these too?
Thanks!
Thanks!
After talking to Bill at RTE yesterday correcting bushings are ok for a 2" lift, assuming you can get them pressed in straight. But beyond that 3-4" lifts should use the longer and caster corrected radius arms.
What do I need to do to make my 3" lift okay. I've already added new s/s brake lines - now it sounds like I need more ...? I only added the lift at your recommendation to support new bumper, winch, etc.
1. Panhard Bar
I'm sorry for my ignorance, could someone explain what the panhard bar does - people are talking about their front end shifting - what exactly do you mean? Shifting in reference to what? Disco Mike refered to turning radius effects - how so? Is this a safety concern?
I've found the recommended panhard bar - I have a 2001 Disco 2 with a 3" Tf lift - any comments?
Lucky8 Llc. - Take the road less traveled...
Can someone tell me about installation? Complexity? Time?
2. Radius Arms
Disco Mike: "...pinion angle which should be adjusted by adding correcting bushings or new radius arms, front and rear"
ebg18t: "...Bill at RTE... correcting bushings are ok for a 2" lift, assuming you can get them pressed in straight. But beyond that 3-4" lifts should use the longer and caster corrected radius arms."
So it seems I need new radius arms too? How many? Front and back? Any recommendations? Is this a safety concern? Sources?
3. ...anything else ...?
1. Panhard Bar
2. Radius Arms
Hey guys - any comments here? I'm really lost. Thanks!
1. Panhard Bar
2. Radius Arms
1. Panhard Bar
2. Radius Arms
I guess know one told you that when you go that extra 1 inch that it will cost you another $1,000.00 to make it work. If you think of mods for land rover just think double or triple and you wont need and defibrillator... add another $200.00 to keep the blood pressure under raps...![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
Chris
Chris
I guess you really don't need it to make it work but it is nicer to have. I would go with the Panhard bar at least because it will bring the axle back in line where it supposed to be. The other stuff is nice but will get very expensive. Your steering will feel twitchy due the caster being off but it can be lived with. Making sure the gears are getting lubed is the other reason for them but at 3" in my opinion you are fine. Hope that helps.
it takes all of 30 mins to install the TF panhard. you should get the track rod with it and make sure justin gets you the ones with the greaseable tie rod ends. use a piece of string to mark the distance between the front of the tire match it to the back for an alignment. bobs your uncle.
