Parking heater for D2
The electronics in my build are slightly different than Keegan's as I wanted to protect my battery from being fully discharged. The small circuit board is a 20A low voltage protector which is connected to the SPST relay. The low voltage protector can be customized to cut power and restore power at set voltage points so you don't kill your battery. The relay is wired so it will cut power to the fuel pump and the heater will sense low/no fuel condition and then properly shutdown. If you pull power from these units while they are hot they can actually overheat and damage their own internal electronics.
dirtlord
Nov 7, 2017 12:19 PM
