part name and torque spec
Following up on a noise under my 95 Discovery, and found that two connectors (one each on LH and RH sides) between the body and frame where I can rotate the bushings on both, but one I can move side to side at the top where the bracket is meant to pivot fore and aft.
Do I need to re-torqued? How tight? Thanks. [IMG]local://upfiles/9729/A11528DB0B4E46FAABAE9034A8D59F8D.jpg[/IMG] |
RE: part name and torque value
It actually looks like a body mount. If these trucks are the same as others, you DO NOT want these loose. These are what holds the body to the frame.
Is there a tightening method or torque spec for these?
One big wrench and a socket, tightening them pretty dam tight is a must.
Thank you. Is it okay to make them tight well past the point that the bushings start to bulge?
Don't go getting too crazy, shear a bolt and you will have even more questions.
| All times are GMT -5. The time now is 04:44 AM. |
