part name and torque spec
Old Apr 6, 2008 | 08:54 PM
snorlax's Avatar
Default part name and torque spec
Following up on a noise under my 95 Discovery, and found that two connectors (one each on LH and RH sides) between the body and frame where I can rotate the bushings on both, but one I can move side to side at the top where the bracket is meant to pivot fore and aft.
Do I need to re-torqued? How tight?
Thanks.
[IMG]local://upfiles/9729/A11528DB0B4E46FAABAE9034A8D59F8D.jpg[/IMG]
Old Apr 6, 2008 | 10:57 PM
Our1stDisco's Avatar
Default RE: part name and torque value
It actually looks like a body mount. If these trucks are the same as others, you DO NOT want these loose. These are what holds the body to the frame.
Old Apr 6, 2008 | 11:56 PM
snorlax's Avatar
Is there a tightening method or torque spec for these?
Old Apr 7, 2008 | 10:09 AM
One big wrench and a socket, tightening them pretty dam tight is a must.
Old Apr 7, 2008 | 12:39 PM
snorlax's Avatar
Thank you. Is it okay to make them tight well past the point that the bushings start to bulge?
Old Apr 7, 2008 | 02:16 PM
Don't go getting too crazy, shear a bolt and you will have even more questions.
chicane
Oct 24, 2014 01:03 PM
utah95
Feb 20, 2014 11:33 PM
wastedincome
Oct 24, 2012 03:10 PM
boris_gti
Oct 6, 2011 11:10 PM
grandkodiak
Mar 29, 2011 03:04 PM
