Part numbers Crossing?
Hi,
I have an 2003 Disco II I want to swap my abs Module will these swap with out issues? The plugs all look alike and they have the same line connections, but the newer one looks a little different on the top it has what almost looks like to plastic vents in the center of the two covers?
I have a installed: WABCO 003 2003 ABS
478 407 020 0
012795
SRB 101241 03 012795
I have to install a
newer) WABCO 003 2006 ABS
478 407 021 0
002906
SRB 101203 06 002906
Thanks
Doug
478 407 020 0
012795
I have to install a
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
478 407 021 0
002906
Thanks
Doug
Mike,
If I where to go to the dealer to buy the pump to fit my truck it would be the SRB 101203 06 pump (the new one). I asked about the one I have in there and they seemed lost could not find the number anywhere... I am not getting that warm cozy feeling I'd really like to have before I start this project .. I have enclosed a picture of the top of both units the "new" one has some vent like holes?
[IMG]local://upfiles/11707/B88845E0CF6F4296BC552BC1F3178341.jpg[/IMG]
[IMG]local://upfiles/11707/561331F50B564DD0818A02F4D07BE644.jpg[/IMG]
Going to get scanned tomorrow to be sure thats what it is... Tried the panic stop with lights on no ABS action. Had scanned before and cleared, shuttle valve and wheel sensor....making sure not wheel sensor.
Doug
Mike did you see the pictures and notice the difference?
Doug
From what I've read in the manuals (and tried) - to do the panic stop, check, it should be done on a slippery surface (at least for my 04) the manuals says if there is enough friction between the tires and the road surface the ABS will not engage (no pumpy pumpy of the brake pedal) and the vehicle will just slow down (or stop depending on your foot) however, when there is not enough friction to properly slow the vehicle down the ABS will engage (pedal go pumpy pumpy). I tried this with my vehicle and it works, dry road = rapid stop, no pedal action, wet road = stopping (slip-stopping) with pedal action. just like the book says
Robert
Robert
Randy P
10-10-2007 03:25 PM
