PCV kit and hose ???
Got my PCV kit from AB and I was wondering why it came with 2 hoses? One thicker one that looked braided and a smaller thinner flimsier one. On mine there's just one hose from the PCV to the plenum. Lastly are there any tricks to getting that flimsy hose on the PCV cause its tight and difficult to fit on. Thanks!
If the hose is rubber, you can spray a little water inside it, and it will slide right on.
There is the hose from the PCV on the pass side and also on the drivers side going to the t-body.
https://landroverforums.com/forum/sh...ad.php?t=19664 If you look in the 3rd pic you can see it, it has a hose clamp on it. I just use old fuel line from a lawnmower to replace both of mine. |
