PCV Valve Cleaning/Replacement
Old Dec 20, 2013 | 08:32 AM
hankeester's Avatar
Here is a pic or two
Attached Thumbnails PCV Valve Cleaning/Replacement-image-1063350232.jpg   PCV Valve Cleaning/Replacement-image-3147878911.jpg
Old Dec 20, 2013 | 09:10 AM
drowssap's Avatar
yup, maybe mine had already been replaced then, the new one i got was also plastic
Old Dec 20, 2013 | 09:34 AM
hankeester's Avatar
so I shouldn't be able to blow through it then? Waiting on an answer before I reinstall it. Soaking in carb cleaner right now.
Old Dec 20, 2013 | 09:49 AM
hankeester's Avatar
I keep thinking it's like a PCV one way valve, but maybe this is not the case?
Old Dec 20, 2013 | 11:29 AM
drowssap's Avatar
no it not a one way valve just re-install in the same direct
Old Dec 22, 2013 | 12:21 AM
Rover_Hokie's Avatar
It is just a spiral piece of plastic in that tube that acts to slow down and catch particles that go up through the spiral. Pictured here on the Atlantic British web page. Not all that sophisticated.
http://www.roverparts.com/Parts/LLJ000010.cfm
You can see the official pre-formed hoses on this page as well that come in the PCV kit that you can get that includes a new separator if you want to go that route, or go like Spike said and just get some hose the same size interior diameter and you are good.
Old Apr 6, 2014 | 11:27 PM
Maui Mike's Avatar
Silly question here but can this be put in upside down? The reason I ask when I removed the hose, all that shows is gold with a little hole in the middle. No nipple. Thanks!!
Old Apr 7, 2014 | 06:58 AM
drowssap's Avatar
it is threaded so i assume if you install it backwards, it possible when the fumes settle rather than running back down the spiral in to the cover the oil would pool in the line?
just a guess though
Old Apr 7, 2014 | 07:39 PM
Maui Mike's Avatar
This is what I see when. I pull the hose off the oil seperator. No plastic shaft and certainly no nipple. Certainly nothing familiar anyway. Will most likely try to pull out but just wondering if this is different than other 2003 Discos.
Attached Thumbnails PCV Valve Cleaning/Replacement-image.jpg
Old Apr 8, 2014 | 07:20 AM
drowssap's Avatar
that's not stock, does that hole go all the way threw to vent
