Persistent Cyl 8 misfire
Ok, working a new to me 03, 13xk miles. DTC 0308 and the occasional 0300
1. Swapped plug with #6 cylinder - no change.
2. Swapped coils left to right, swapped used injector in position number 6, #6 injector in #8 position, new plug wire on #8 coil. Still DTC 0308
Other symptoms
-02 sensors switch properly
-Only other code is the occasional 0300 (multiple misfire)
- runs fine at speed, although will occasionally idle really rough, then just stop
- will not set the dtc if the code is cleared while driving, until truck is idled again.
At this point, I seem to have ruled out plugs, wires, coils, and injectors. So what else is left?
1. Bad valve?
2. Blown head gasket on #8 (truck runs fine, 180 degree inline stat with 185 temps, drinks no water)
3. Bad injector wiring?
4.
What else am I missing? And why does it randomly start idling rough, then just go away? It's very strange.
Other symptoms
1. Bad valve?
4.
Other symptoms
1. Bad valve?
4.
Other symptoms
1. Bad valve?
4.
Now a bad MAP sensor or idle air control motor could be a definite possibility for a P0300 (random misfire - not making the proper adjustments - especially at cold start or during idle)- but not sure it explains only cylinder #8, unless the vacuum leak is only on that cylinder. This train of thought has definite possibilities - anyone ever run in to that?
I am having similar issue with #6 and #8, however, when I pulled wires and plugs and grounded to manifold, I got no spark from plug. Changed plug and wire still no spark. now I ordered new coil packs, but if there is something else I could check, I would prefer to not have to replace the packs.
Codes are:
P1300
P0306
P0308
Codes are:
P1300
P0306
P0308
Codes are:
P1300
P0306
P0308
Codes are:
P1300
P0306
P0308
BTW, you might want to start a separate thread...
