A Pillar Install
A Pillar Install
So I just purchased a set of replacement A pillars. There was a thread a couple years ago where a guy did the install using screws that attached to the clips. Plastic caps looked they covered the screws.Think there was a falling out and the post/pics were removed. Anyone have a lead on how to do this?
I still want to do the screw mod on my new A-pillars but I’m working on other things to do on Myrtle.
I couldn’t find the a-pillar mod pics but here they are from a consolidated post... https://landroverforums.com/forum/di...-effort-92607/
328Driver (07-29-2019)
I had both of mine randomly fall off a while back.
I just carefully drilled out a hole and the used a random screw to reattach them to the original clips.
Not fancy, but they’ve held now for a good while.
And some standard scrivets on top to hide my sins.
I think if I had it to do again I’d fill the clips with caulk (or hot glue if you’re impatient) before I tried to jam the screws in.
edit: mine were the interior ones. You might mean the exterior.
