Plastic housing over tag removal
Trying to remove the plastic housing over the rear tag to install a switch. Any one have any luck takeing it off? I have pulled every nut that seems to hold it on to no avail. Rave was no help.
Are you talking about the cover for the cargo door?
It's the housing that hold the outside door handle and tag lights.
Have you got behind the Land Rover emblem? It just pulls off and I think there is one 10mm behind there.
Pop off the Land Rover Logo with a screwdriver and I believe there is a bolt holding it on.
1 Attachment(s)
The handle comes off with two nuts from the inside. It's in Rave.
https://landroverforums.com/forum/at...1&d=1401902047 |
aww behind the emblem,,,, i need to install the full rave, thanks guys
