Plastic housing over tag removal
Old Jun 3, 2014 | 02:03 PM
Swampmonster's Avatar
8th Gear
Default Plastic housing over tag removal
Trying to remove the plastic housing over the rear tag to install a switch. Any one have any luck takeing it off? I have pulled every nut that seems to hold it on to no avail. Rave was no help.
Old Jun 3, 2014 | 09:12 PM
ralphobell's Avatar
Are you talking about the cover for the cargo door?
Old Jun 4, 2014 | 12:00 PM
8th Gear
It's the housing that hold the outside door handle and tag lights.
Old Jun 4, 2014 | 12:03 PM
morbengan's Avatar
Have you got behind the Land Rover emblem? It just pulls off and I think there is one 10mm behind there.
Old Jun 4, 2014 | 12:12 PM
ralphobell's Avatar
Pop off the Land Rover Logo with a screwdriver and I believe there is a bolt holding it on.
Old Jun 4, 2014 | 12:14 PM
jafir's Avatar
The handle comes off with two nuts from the inside. It's in Rave.
Old Jun 4, 2014 | 10:43 PM
8th Gear
aww behind the emblem,,,, i need to install the full rave, thanks guys
Doc Fluty
Mar 22, 2013 11:21 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
ara25
Mar 25, 2011 08:27 PM
2000_328ci
Feb 6, 2011 10:38 PM
bean0714
Dec 19, 2007 04:20 PM
