Plastic Plug on Top Left of Radiator
I have a 1996 Disco I with the 4.0L. I have finished that 60k maintainence thing mike posted up above.
After I got done pooring in the coolant I removed this plastic plug from the top of the radiator to burb the system with (thats what it seemed it was there for). After running the engine about 10 minutes, I put the plug back on and went about my way.
About two weeks later I was driving around town and saw the temp guage go waaay high, it never went into the red, but it was really close. I turned the heater on full blast to get me to a place I could pull over (this reduced the temps a little bit according to the guage).
I pulled over and popped the hood and could hear the system leaking at that bolt, so I grabbed a wrench and went to tighten it and the top broke off. The damn thing is hollow on the inside so half the plastic peice is still in there. I can't find this peice anywhere so I put a 3/8" bolt down in there and put two tubes of appoxy over it.
Is this a decent enough fix, will I have to buy a new radiator just to get the plastic bolt?
Thanks
Brian
Thanks
Brian
sounds like you have the old style upper radiator hose, that needs to get replaced.
Atlantic British sells the new style hose, it has a "T" and a Bleed Screw on top.
when you go to replace the upper hose you might want to have a replacement thermostat
ready to put in since you are gonna need to unhook the upper hose from the thermostat
have some coolant on hand, a couple gallons of aluminum safe coolant because it will drain out and be a mess, good luck , keep us posted.
These guys are thinking that you have a DII, you have a DI, TOTALLY different animal.
You dont need to buy a whole new radiator.
Just buy a new plug.
www.atlanticbritish.com will sell them as well as your dealer and like it is suggested just go to the hardware store and buy a brass plug to screw in there.
You may want to use some teflon tape on the threads but that is up to you.
Read my sticky on how to bleed a cooling system, read the replys too as I cover a DI also.
D1's dont have a bleed fitting in the upper hose like a D2. Shame, cause I think the plastic plugs on the radiator must be one time use.
roverparts.com sell the plastic plug.
edit: My link takes you to the plug
![Stick Out Tongue](https://landroverforums.com/forum/images/smilies/peaexB2.png)
