ok, sounds good
(Post 660785)
Check fuel pressure, it obviously has spark if it starts right up with ether.
Brian. |
Originally Posted by No Doubt
(Post 660766)
You know that you have low fuel pressure since it starts with starter fluid but not without. Could be the fuel pump relay or even a corroded relay or fuse box, but is most likely a dying fuel pump (easy to replace under your back hatch carpet).
[QUOTE=No Doubt;660766]You know that you have low fuel pressure since it starts with starter fluid but not without. Could be the fuel pump relay or even a corroded relay or fuse box, but is most likely a dying fuel pump (easy to replace under your back hatch carpet).[/QUOTE
so im guessing that the engine is sucking its own fuel into the motor in higher rpms? then once it gets to idle it cant pull enough fuel for its self to run off of? or is the pump weak and cant pump enough? it will run as long as i want, just as long as it doesnt drop under 1000ish rpm |
" i don't want to have to buy an expensive pump."
I know its a bad time for this reminder, but you bought the wrong car for that kind of attitude. Owning a Land Rover one should know going in that proper maintenance is not an option but a requirement. The only way to cut the cost is to do the labor yourself. AB has them on a Flash Sale right now. |
Originally Posted by RubyRoverD2
(Post 660799)
alright, is it possible to rebuild the pump in the disco? i don't want to have to buy an expensive pump.
The Bosch replacement pump is just $136 at RockAuto: https://www.rockauto.com/en/catalog/land+rover,2000,discovery,4.0l+v8,1363496,fuel+&+a ir,fuel+pump+&+housing+assembly,10147 The actual Land Rover fuel pump from Atlantic British is $224 during their current flash sale. Some people use a generic inline fuel pump, which can be as cheap as $35 but requires doing your own electrical and fuel line plumbing. Others buy a used fuel pump. I picked one up on eBay for less than $40, and local wrecking yards sell them even cheaper. ...but... before doing that, let's first *TEST* your Disco 2 to see our problem. Heck, a bad alternator/battery (failed internal cell) can reduce fuel pressure. So start her up with starting fluid and rev her a bit to keep her going and then... Turn On Your Headlights, foglights, radio, and step on your brake pedal. If your problem is marginal voltage to your fuel pump, then the above might identify a problem other than, or in addition to, a tired fuel pump. Test first! |
I had vey similar symptoms and it was the fuel pump. When you turn the key to position II can you hear the pump prime? Pumps are cheap and easy to change out. But, yea, check the relays, alternator, battery etc first, but I’d bet it is the pump. |
Push the inertia switch on the firewall and see if it clicks. Weird things happen sometimes :dunno: |
o
Originally Posted by Dave03S
(Post 660801)
First ensure the autobox gearshift is in P or N. Switch the ignition key to 2 then open the rear door and if the pump isn't whirring it is dead and there are no serviceable parts so it will only take the cost of a new pump plus the rubber gasket. The D2 will only start in P or N.
To change the fuel pump is a simple 2 hour max job, see here: www.discovery2.co.uk / TD5 Fuel Pump replacement. You don't need to remove the rear side panels for access as the carpet usually slides out underneath the panels. The V8 pump is normally the same or similar type to the TD5 but with less connections into it but it's in the same location. |
fixed!
Originally Posted by redwhitekat
(Post 660760)
Sounds like gas issue. Check your fuel pump relay exchange it with another. Next I would look at your fuel pressure I think the shrader fitting is behind intake manifold check if you have pressure |
