poor mans roof rack build with pics...
hey guys,
i really wanted a roof rack, and after seeing the other posts about making your own roof rack i decided to take a shot at it. here is what i'm doing to build my own roof rack... i dont have any plans persay i'm just wingin it as i go.
if you have any comments...constructive stuff, nothing negative i'd love to hear them so i can improve my project. for starters...
i have a supply of EMT 3/4''(inch) x 10' about 120' (feet) in total, for bends i'm using a standard rigid 3/4'' EMT bender found at home depot for 39.99$, if you can find a cheaper bender great... its all the same .....in theory
Tubing comes in 10' sections at $ 2.47 per tube. So 120 or so should cost you $ 29.64 plus tax. for rough joint MOCK UP i'm using simple 3/4'' emt joints. they have a set screw on either side to old the pipes in place enough for you to make measurements and such. i plan to tack/mark these tubes in place and then have a local welder do a really good job on them in his shop. i cant find my camera but i'll grab pics in the morning.. dammit
I know you have been looking at my rack as an example, I would find a local steel supplier to get the metal from. They will come inlonger lenghts but the steel will be more what you want and will weld easier. The tubing bender is going to be tough to get them all the same and uniform. I would say to go to an exhaust shop or a fab shop and have them do the bends for you. It should be somewhere between $8-$10 per bend and at least you know they will be right. For the 8 bends it will add some cost but nothing too excessive.
Good luck on the build and keep us updated.
Good luck on the build, keep us posted.
If you are going to use the EMT screw connectors, you could make it stronger by lining up the connector/emt to where you want it - then remove the screw mark the EMT through the screw hole then drill the EMT, then install the screw. This way the screw goes through the pipe/EMT ---instead of crushing it (its normal configuration), this way it could withstand a little lateral force without coming apart. EMT by nature has no stresses applied to it - only - through it (pulling in the wire).
