Posting pics info requested.
Yeah, really don't see any "smoking gun" as far as gasket issues. They certainly were due though. #7 looks pretty carboned up, #1 too. But #2 looks about par with rest of cylinders on that side. Maybe have the injectors tested while a part and check harness over closely for wire damage. Were you loosing anti-freeze?
Brian.
Brian.
Disco cyl head resto
No I don’t either my go to machine guy looked and said signs of driver side coolant leak from the back of head inside to outside. He told me right away they were like gm heads ( Buick) and of course they are he is skimming faces and lapping valves new seals So another question although had no lifter noise before but as they are accessible now should I remove strip down clean them because I can or leave alone lots of utube vids of guys doing it comments please. Also am I safe to scrub down in belly pan pretty gunky was going to scrape while vacuuming then flush and of course change oil after.
It sounds like you've got this engine pretty stripped down, and you're heavily invested in this engine. I would suggest you consider pulling your crank and pistons and redo your crank bearings and piston rings. You don't get many shots at that.
Dont **** Togo that far
I just want todo well o the top end it was a solid runner before all started over a misfire I have a spare disco with two conecting rods gone I’m Going to completely restore that one trans And all give it to my son as his inheritance lol no really I’m good with doing top end I’m only in as much as theexchange is can to us I’m 70 now so it will last me still have my olds rocket 88 to finish and my67 bsa lightning cafe bike.
Thanks
I will do that I was using a mix 87and premium before the misfire some on here said if u can’t afford premium gas don’t own a Landy I feel he was right I’ll be running premium from now on. Havnt had the chance to go far as yet plan to though no none in my area services injectors will try testing my self individually don’t want to risk not knowing if that was the problem
