Power Steering fluid
on
Too messy to remove the hoses and you still leave lots of old fluid in the gear box.
Suck all the fluid out, I use a turkey baster typr hand bump I bought from the auto parts store, refill, start the engine, turning the steering wheel full turns both ways, turn off the engine and repeat a total of 3 time.
If you can find a synthetic p/s fluid use it, other wise any well known brand of p/s fluid, no atf.
The method that I use is to remove the return line from the bottom of the P/S bottle and stick it into a empty washer fluid bottle.
Have a friend start the truck, with it ideling keep the P/S bottle on the truck full, once the fluid that comes out of the hose is the same color as what is going in have your friend turn the engine off, fill the P/S bottle and you are good to go.
DI's take Dexron and DII's take Power Steering fluid.
