power steering fluid type/mix ?
I Don't know what type of power steering fluid the person I bought my 2000 disco from put in it. Its at the lower level mark and I just wanted to fill it to the top mark. Is there a way to tell what type of power steering fluid in it? If not what type of power steering fluid can I use to fill it to the upper mark our is mixing a small amount into another type of power steering fluid a bad idea? I don't have the money right now to drain and refill with Valvoline synthetic like I would rather do.
Originally Posted by aftermath431
(Post 440394)
Maybe someone else will have a different opinion, but I'm happy with my decision. |
I use the Lucas stuff to top off
Lucas can be used but drain and refill it with LR specified fluid as soon as you have the budget. Before I used a regular PAS fluid and my pump failed after 2k miles. I don't know if it's just a coincidence or a bad luck. Now, I don't want to take any more chances.
(Post 440394)
Amsoil works verry well for me in all my vehicles get a account or just go to the site. I've done some bad stuff to vehicles and powersports toys in the past and I can only point to the lube as the reason it did not cost me big money |
(Post 440394)
Thanks for the help i'm going to drain it and refill with oem our pentosin since I dont know whats been used in it.
(Post 440935)
Its so easy to flush its quick and easy just use the wife as a helper to start and stop the truck . Any quality fluid will do the trick synthetic is better but paying a premium for oem specific fluid is a waste. Just get something that exceeds specs |
Do yourself a favor, don't drain if, flush it and just use standard p/s fluid. It will take about 4 quarts of p/s fluid and this should be done every 25,000 to 30,000 miles.
DiscoMike, or anyone else who knows -
Is it okay to use Dex ATF fluid in for power steering fluid in a 2004 Disco and if not why? Thanks guys. |
