TRIARII |
08-30-2014 10:01 AM |
power steering leak trigger 3 amigos and clicking metal sound
On my way to work today and and I noticed that my power steering pump is a bit louder than it has been, so I pulled over and checked the PS reservoir, it was still almost full but I decided to top it off anyways using a funnel. After I poured the fluid in and removed the funnel a couple tabelspoons full of fluid came gushing out of the reservoir and made a mess of things, cleaned up the reservoir, capped it and went on my way to work. 15 miles later I make a turn and I hear a loud noise coming from with the engine bay or underneath the truck up front near the drivers wheel. Could not tell if it was more of a clicking or more grinding, but right after the noise the 3 amigos came on followed by a pending check engine code on the Ultra Gauge. Have not checked the UG pending code yet because i did not think it would be related. I have had a ghost vacuum leak code come and go for a year now so. But anyways often times when I make a sudden turn i hear the noise again. I inspected beneath the truck and I did not see anything broken or any metal shavings. The brakes are brand new (calipers, rotors, pads) front and rear so I know its not a typical brake issue. But I did notice alot of fluid on the back side of the front driver disk brake and all over in that general area.
If power steering fluid managed to get on/in all the components on the back side of the disk brake, would that cause any issues with the truck?
Sorry I cant show you the noise, my 3rd htc **** the bed so i threw it in the trash while I was pissed.....
