Powerstroke V6
Powerstroke V6
I understand that LR is now using the V6 version of the Powerstroke in the new LR4. Has anyone given any thought to using one of these as an upgrade? Hint they are being used in the Ford LCF, so they are definitely EPA approved.
Cold weather has hit and my fuel economy has tanked, so I am back to thinking about this kind of conversion.
This horse has been beaten to death, buried, dug back up and beaten again, then fed to a dog and once it comes out of the back end of the dog it is beaten once more.
It will cost you $10,000 to do a diesel conversion, and for a DII the TD5 is the only engine option that is still a Land Rover engine.
You can go with a International TDV6 if you dont want the Land Rover engine.
$10k will buy alot of petrol.
I am sure our transmission will not mate up to it but do not hold me to that.
Spike is right, you can but a lot of fuel for the amount it will cost to do the swap. I have considered it since my work gives me $5K a year for using my own car. With the mileage and cost I could make it out a head after three years (since I still need to pay for gas). The coolness factor is worth something too.
You would need a diesel transmission to mate to your diesel engine because the shift points are different.
The diesel would cruise around 1500 rpm on the expressway while the V8 cruises around 2500 rpm.
The cheapest way to go would be to order a used TD5 and TD5 transmission from the UK.
You would also need the trans computer, the engine computer, the intercooler, fuel lines, fuel pump, exhaust as well as other bits I am not thinking of.
Then once it is all installed it would need to be flat bedded to a dealer to have the "new" ECU and the alarm synced so you could drive it.
Then once all that is said and done where are you going to get air/fuel/oil filters let alone someone to work on it?
Your LR dealer techs wont be trained in the diesel.
You would have to buy your timing belt and filters from the UK.
http://cgi.ebay.com/LAND-ROVER-OIL-F...item5ad5ff8ea9
http://cgi.ebay.com/Filter-Kit-suit-...item415455b688
This engine here is for a DI.
http://cgi.ebay.com/ebaymotors/landr...Q5fAccessories
I dont mean to be a spoil sport, but lets face it, its a pipe dream.
