Practical Reasons for 2" lift?
Old Mar 25, 2013 | 08:36 PM
caymandrew's Avatar
Default Practical Reasons for 2" lift?
Guys,
I only get off road for fun rarely. I'm going to be replacing my shocks and wonder if I should just do the 2" lift kit? I'm wondering what other practical reasons other than better clearance off road? I guess larger tire size, what else? If I'm 90% on road will I get any benefits?
Old Mar 25, 2013 | 08:51 PM
taylor15's Avatar
I know wreckdiver said his overall ride improved. I think you will gain on road by replacing the 10+ year old shocks no matter what
Old Mar 25, 2013 | 09:03 PM
MC04DII's Avatar
Well shocks alone won't give you a lift. You could save about $250 and just buys shocks without new springs (for a lift). That will give better ride quality. If you lift without going to a bigger tire, it will look a little small wheeled and funny.
Old Mar 25, 2013 | 09:08 PM
To answer your question, none.
There is zero benefit to installing a lift of any kind if you are not going to run oversized tires or need more ground clearance.
Old Mar 25, 2013 | 09:11 PM
MC04DII's Avatar
It may discourage shorter people from riding in your truck, so there's that.
Old Mar 25, 2013 | 09:12 PM
wreckdiver1321's Avatar
I don't know about that. A new suspension, especially if you're just running stock stuff now, will vastly improve the ride comfort. A medium duty kit seems the way to go for you.
Old Mar 25, 2013 | 09:22 PM
Hey now! I'd take offense to that if I was offendable, I'm all of 5'5" and getting shorter by the year.
Old Mar 25, 2013 | 09:28 PM
caymandrew's Avatar
Right, well I had planned to just do the shocks as they are the factory ones, I can get her bouncing pretty good just pushing on the bumpers so they are shot. It's only a couple hundred more for the 2" lift kit including all four shocks and springs:
Terrafirma 2" Lift Kit Discovery II
The install to swap out the springs is much more involved as I'm doing this myself. But not planing on over sized tires and not needing ground clearance, I guess I'll take the easy road and just do the four shocks. Do those springs really go that bad after 12 years?
MC04DII's Avatar
Well, I should have said vertically challenged people who don't appreciate jumping in a well appointed Rover. This would not apply here . I'm 5'11'' and have to give a little jump to get in mine.
Old Mar 25, 2013 | 09:31 PM
MC04DII's Avatar
Actually the spring change isn't much more involved. If I remember correctly, I had to take out the front springs to get the front shocks out. And as for the rear,those are pretty easy. Not sure how much a difference new springs would make compared to old springs and new shocks. Thing is though it will look a little off with 29'' stock tires.
