Pressing brake pedal causes instrument cluster light brightness to change
Old Nov 14, 2010 | 05:01 PM
ringerso's Avatar
Question Pressing brake pedal causes instrument cluster light brightness to change
Just got in from a few hours of wheelin' on local trails. We got pretty wet/muddy, and also went to the carwash afterward. On the way home, I noticed that pressing the brake pedal was causing the interior lighting (IE. instrument cluster, radio, etc..) to change to the brightness of when headlamps are turned on (letting off the brake pedal results in the brightness reverting back to normal). I checked all of the running/brake lights, and all are operational, as I thought this may be some type of warning that a bulb was out, etc... I'm assuming it's probably just some electrical weirdness from the all the water, but was wondering if anyone else had run into this issue? I tried searching the forum and RAVE, w/out success.
cheers,
rich
Old Nov 14, 2010 | 05:26 PM
Every GM car I have ever owned did this from brand new, the fault was to small of a battery from the factory and the alt being to small and it could not keep up with the added amp draw.
When the OEM battery went bad I always installed the biggest (amp) battery I could and the problem always went away.
So...have your battery and alt tested if it continues after everything is dry.
Old Nov 14, 2010 | 05:36 PM
ringerso's Avatar
Thanks Spike, appreciate the reply.
Old Nov 14, 2010 | 08:44 PM
novadisco2's Avatar
you can also try an alternator test with a midtronics tester or equal, It's possible their is a shorted diode in it to.
LADEROUTE
Nov 6, 2012 05:56 PM
bjcavender
May 23, 2012 08:52 PM
datoshway
Aug 24, 2010 04:59 PM
Greg
Aug 8, 2007 04:47 AM
bigbris1
Jul 3, 2007 08:02 PM
