Problem with a V8 petrol engine.
Old Jan 27, 2010 | 03:01 PM
oferl's Avatar
3rd Gear
Default Problem with a V8 petrol engine.
Hello everyone,
My question is regarding a 95 model discover with a 3.9 Liter V8 petrol engine.
Does anyone heard of a problem of cylinder#8 "sinking" and cooling water goes into the cylinder from the gap between cylinder6&8. I've been told that this is a "known" problem of this kind of engine and there is nothing that can be done beside replacing it. Is there a way to fix it otherwise?
Thanks.
Old Jan 27, 2010 | 03:19 PM
lipadj46's Avatar
Sure you can overheat the engine bad enough and the steel cylinder liner can slip as they are just press fit in. You can fix it but unless you do the work yourself (pulling the engine, stripping the block, then paying big money to get a new sleeve put in, reassembling the engine and reinstalling) it is cheaper to buy a used engine.
Old Jan 27, 2010 | 03:20 PM
okdiscoguy's Avatar
This is an aluminum engine with steel liners. When overheated, the liner will drop and the engine is toast. It is more to put in a new liner than you can replace the block for.
landlro
Jul 2, 2014 10:48 PM
RoverBuild
Jun 1, 2012 07:27 AM
rodwhirity
Mar 7, 2012 07:00 PM
cadare
Defender
Sep 28, 2008 05:43 PM
simonjf1973
Feb 16, 2008 05:07 PM
