Problems Starting
Problems Starting
Hi All
Purchased a 2000 Discovery 2 back in May this year, with a known immobilizer issue.
Since then, the following has taken place to try and solve the issue:
· · Replacement BCU, ECU sent away to be linked with new BCU and Keys – cannot open though using key fob, although LED is flashing so presume sending signal. Everything seems to work as it should except car will not start. Therefore…
· · Key Receiver in headlining replaced and relocated to prevent damp problems, wire earthling casing in new location.
None of this has seemed to work having got the new key receiver through today. The light on the immobilizer has also stopped flashing it appears on the dash since I last connected the battery, so wondering if its an issue there, but basically running out of ideas in regards to what I could be.
Your help in anticipation...
earlyrover
08-08-2015 05:32 PM
