Project Discovery 2, need help with transfer case shifting
Hello,
I have a project D2 1999 that i bought non-running. the engine is out getting top hatted liners.
In the mean while i thought i would install a CDL lever from a D1 everything fit great, and the diff locks and unlocks very smoothly. I tested it by lifting all the wheels in the air. I bought the full kit with the shifter mechanism, HI-LO shifter box (the long one on six bolts with the breather hose on it) and TCU computer.
My trouble is, i cant shift the H-N-L shifter at all. I have removed the interlock cylinder and no difference. I can push the lever forward and it just pushes a little spring loaded pin sensor, but i cant pull it back to neutral or Hi.
Any ideas?
Does there need to be a running engine in the car?
Thank You
Any ideas?
Thank You
Hello,
Any ideas?
Thank You
Any ideas?
Thank You
No that's wrong. I just checked mine. It would not shift out of neutral without the engine on and the gear shift in neutral.
Unless all moving parts in the transfer box are lined-up just so, the selector sleeve will not be able to engage on the hub. Without a rolling chassis, I suppose you would need to remove the bottom cover plate and rotate intermediate gears manually while simultaneously moving the selector shaft. If that doesn't work then most likely the detent ball and spring are seized from lack of use and moisture. Start at page 526 of RAVE workshop manual. The issue that you propose is why LR instructs to have the vehicle rolling slightly in neutral while shifting between low and high.
Thank you very much for trying. Can you please also see what happens if you put the transfer case in low, then shut off the engine and try to shift into neutral or hi? Then again the interlock might fight this...
My automatic was in neutral when i tried. I also tried in park with no luck.
I hate being towed. Shameful.
On the lever ****, how much movement should there be from low to neutral to high? Something like an inch between each?
I did. I could shift to neutral from hi or low with the engine off but not out of neutral. I guess this makes good sense form the standpoint of a tow... If the engine wouldn't start I could get out of AWD for the tow... Anyway, that might not have been the intention but it is good to know. When I have been towed I put both the transfer case and transmission in neutral.
Thank you very much for the reply. Makes sense about the parts being aligned. I will take off tbe cover and give it a shot next week. I need to change the gear oil anyway.
In follow up to previous reaponse. Could you please provide more detail on tbe ball and detent? I read about it in the manual but theres. Not a picture and i do t really know where to look for it.
Thank you
Hello Everyone. I am currently traveling and cant make any progress on the car, but I realized I may have made a big mistake when installing the hi-lo selector. I put the lever inside the transfer case between the selector rod and the spring loaded sensor. So basically my transfer box is in High, and by pulling back on the lever I was only forcing it "High-er"
Turns out the lever goes in a flat slot machined on the side of the selector rod. I will post my results next week. I don't know what I was thinking......
