prop shaft and ujoint grease
Hello all.........This may be a dumb question but can some one please tell me the right amount of grease to be applied to the u joint and prop shaft.I normally just pump it until i see new grease but i NEW to LR's and i dont want screw anything up.Also i will be using a auto and marine type grease if thats OK.
Thanks all for your input............;) |
Your choice of grease is fine, I use farm implement grease.
U-joints are u-joints, you grease them all the same. |
Originally Posted by Spike555
(Post 315124)
Originally Posted by sorbet35
(Post 315127)
The rave shows where to grease it but not the amount.This is a great forum!!
i just pump the grease till i see it come back out the u joints. |
itll force out the old stuff plus any water contamination etc... i dont think you can overfill em ;)
(Post 315122)
| All times are GMT -5. The time now is 01:20 AM. |
